Inventor Pro 2020.
Created a simple extruded circle Part.
Created a Text User Parameter and used it's value in a Leader Text 3D Annotation.
So if the value changes in the Parameter, the 3DA changes.
If I delete the 3DA, the Parameter is also deleted...!!!
Is this normal behaviour...???
Thanks.
Solved by steve.gloverHMA8M. Go to Solution.
I can reproduce it in 2021. Looks like a bug to me!
If you add a second one to the same leader it deletes only the first.
@johnsonshiue are you able to look into this...
Hi Folks,
This does look like a bug. It is wrong. Let me work with the project team and see what we can do.
Many thanks!
This happens when the leader is deleted through the API also
Hi! The issue has been reported as INVGEN-50117.
Many thanks!
Thanks @johnsonshiue & @gcoombridge
I found a workaround which may give us a quick solution.
I included the same Parameter in a sketch that wasn't used by any features.
When I deleted the 3DA the Parameter did not delete because it is being consumed in the sketch.
Would be an acceptable solution/workaround for now...???
Cheers..!!
