Defer Update Toggle/shortcut?
mslosar
Advisor Advisor
mslosar
Is there some undefined shortcut or something that activates this? I have never turned it on intentionally, yet the thing routinely pops back on. It's infrequent enough that I don't recall the cause of the issue i'll be having, then i look up and it's 'duh'. But what the hell keeps turning it back on??
I want it to stay off and if there's a shortcut I want it removed. I did look in the customize dialog and nothing is assigned to it.
mcgyvr
You can assign a hotkey to it.. Seems like you have checked that though..
Have you installed all updates?
I keep having the save reminder turning back on and can't find a trigger so its certainly possible that there is a bug/workflow that may cause an issue..
mslosar
Yeah, i'm on 2019.4.4, so i'm as up to date as I can be until fall when we go to 2021.
Seems to recur more under 2019 vs 2017, but it's annoying nonetheless 🙂
johnsonshiue
Hi Mike,
Is this about Assembly Defer Update or Drawing Defer Update? They are two different commands. The Drawing one is controlled in Doc Setting, while the Assembly one is an App Option. I am not sure if there is toggle for either.
Many thanks!
Software Test Engineer
