This is hard to understand without doing it yourself. I've tried to explain this a few different times with some amount of confusion still existing. So I'm just going to explain the steps for everyone to reproduce.
Issue:
I have assemblies with this feature working in Inventor 2019 without problems. This defect / bug occurred after we updated to Inventor 2022. Basically if you have a 'iAssembly' 'Factory' with multiple 'Members'... i.e. Assy1, Assy2, Assy3, Assy4.... and inside these, you have another sub-assy (which is also an iAssembly) with multiple Members and the sub-assembly is set to phantom... each member of the phantom iAssembly would be called Sub-Assy1, Sub-Assy2, Sub-Assy3 and Sub-Assy4... The resulting idw drawing will output a Parts List that doesn't display all Parts within those members of that phantom iAssembly. (Key word is Parts within those Members!)
Example Image:
Steps for reproduction:
Notes:
There's a few extra weird things that happen during this bug.
Goal:
Additional Search terms:
Defect: Factory with a phantom Factory not displaying all parts from each Factory member.
Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
Solved by Hunteil. Go to Solution.
Updated OP: Added Notes section and attached the the .zip file with an example similar to the steps to reproduce.
So feel free to give it a try.
Hi! Many thanks for sharing the files and the findings! This is absolutely a bug. I tried it on our latest internal build targeting 2022.3 update. It has been fixed. The PartsList is exactly like what you are seeing on 2019. The update will be available some time in April.
Thanks again!
I can officially state this bug is fixed in 2022.3
A little follow-up issue on my side. Our job processor isn't updating our exports correctly (bug is still present). It still shows the incorrect BOM issue that should have been fixed. I went into the server and updated it's Inventor and the Vault Server 2022.2.1 to 2022.3, then to 2022.3.1. Then IISRESET and b2bmigrates with a Autodesk Vendor support helping me... Then updated our job processor too... and it still outputs incorrectly. Case is still open atm. If there's any guidance, please feel free to share. Otherwise I'm depending on the Autodesk Vendor's Support to troubleshoot this. I think our next step is to uninstall everything and reinstall everything on both the Server and the VM we use for my Job Processor.
