Default to "NO" when exiting document! Come on...
chrisw01a
Message 1 of 8
chrisw01a
Autodesk, please change this to default to "Yes"!
When you click the "x" in an open document, this dialog comes up. It used to default to "Yes" which I would quickly press "Enter" on the keyboard to continue.
Is there a setting for this?
Thank You.
Replies (7)
Message 2 of 8
chrisw01a
Message 3 of 8
chrisw01a
It would appear that it is choosing whichever option you chose the last time including "cancel".
Can we force this to "always prompt" with a "yes" default?
Message 4 of 8
BDCollett
Thank You.
It seems to actually remember what you did last, it does not default to NO.
It did use to default to YES.
There have been other posts about this. An option to choose the default would be handy.
Message 5 of 8
pcrawley
Does this help?
Peter
Message 6 of 8
chrisw01a
No, It defaults to the last option you clicked on.
If you close the document and select "yes", the next time it will have "yes" highlighted. If you clicked "cancel", it will have "cancel" highlighted. If you clicked "no", it will have "no" highlighted.
Message 7 of 8
gregory_nickol
@chrisw01a Are you aware that instead of hitting "Enter" you can simply hit "Y" or "N" and it will function as clicking yes or no respectively regardless of what is currently highlighted? Depending on you're resting hand positions this may be just as useful. That is the workflow I use personally because it eliminates the possibility of hitting enter with the wrong one highlighted.
Message 8 of 8
chrisw01a
I did not know that! I will give it a try. Thanks
