I have a part of a model that I have made and I was wondering if there is a way of making the element of it sticking out to be able to go inwards without completley designing the model again?
Here is a picture of the model:
P.S i am using Inventor 2014
Simply edit the Extrusion feature and change to Cut rather than Join.
Attach your *.ipt file here if you can't figure it out.
Hi! Like JD suggested, you can edit the feature and change the type of operation. Or, you can use Direct Edit -> Move -> select the face and drag it outward.
Thanks!
