Cylindrical Maze
Cylindrical Maze
Message 1 of 9
Cylindrical Maze
I've tried making a tangent work plane to my cylinder, sketching a maze, then using project geometry. This method just sktreches the sketch through the object and I don't know how else I would acheive this effect.
Any help is apprectiated!
Replies (8)
Message 2 of 9
JDMather
Attach your *.ipt attempt here.
Are you familiar with Emboss command
or
are you familiar with 3D Sketch wrap to face?
Message 3 of 9
My attempt is attached and I made the edges of the maze the correct size so that it could wrap around the circumference perfectly. And the maze is just a quick one I sketched on there so I still have to tweak the dimesions so the path width is uniform.
And I've only been using inventor for a few months now so i haven't used those tools, but am excited to learn how to use them.
Thank you.
Message 4 of 9
JDMather
While someone takes a look at this file -
I recommend that you download and install the Service Packs and Updates for 2014.
If you are a student - is there a reason you are not using Inventor 2017?
Message 5 of 9
Yes, I use inventor 2014 because my school uses 2014 and if I used 2017 at home, it is my understanding that there would be problems opening it on a ealier version or vice versa.
Message 6 of 9
JDMather
OK, just checking.
You would not be able to open 2017 files at school.
But, is there a reason your school is not using Inventor 2016 (Inventor is now free to schools, I don't think it was back on 2014).
First thing I notice is that you have rounded off the circumference - I would enter as an equation the dimension variable name *PI (see image).
In the image, the top and bottom line will wrap to the same line, so I changed one of them to Construction linetype.
You are missing many many many horizontal and vertical and equal constaints and also dimensions.
You will start a 3D Sketch, select Project to Surface with the Wrap option.
Message 7 of 9
Thank you so much for your help and I will definitely come back with any follow up questions.
Message 8 of 9
The next step would be how can I extrude the walls of the maze?
Message 9 of 9
JDMather
Given your level of experience -
I am going to recommend that you model this in flat form and then Bend or Fold into a cylinder.
