Spherical inclusions in sphere.
Hello, I am trying to generate a sphere with a set number of spherical inclusions inside.
The number and position of the inclusions depend upon their size (I do not want inclusions outside of my sphere)
I want them evenly spaced in the 3 dimensions (the distance between two inclusions is 4 times the radius of the inclusions).
Is there a way in Inventor to automatically generate the inclusions ?
JDMather
What version of Inventor?
Can you attach your initial *.ipt attempt here?
My version is Autodesk Inventor Professional 2016,
I didn't go very far, I managed to create a sphere and then I created a smaller sphere.
I didn't go father because if I wanted 100 inclusions I would have had to copy my part a hundred times and I was wondering if there was a way to automatize it ?
Curtis_Waguespack
Hi Anthony_Mostly_Harmless,
I know this isn't exactly what you're asking, but see if this golf ball model gives you some hints as to how to use patterns for this:
http://forums.autodesk.com/autodesk/attachments/autodesk/78/397945/1/Golf%20Ball.ipt
I hope this helps.
Curtis
JDMather
First thing I notice is that your Sketch1 is not fully defined.
You are missing a Coincident constraint to the center point and missing a Vertical constraint.
These issues will become important as the complexity increases.
2nd - do you want this as an assembly, or do you want as single part?
3.  Do  you have a link to an image of a design similar to your design intent?
Ok thanks i've added the constraints.
The program I import it in requires an assembly
I am looking to make a similar model to this (except in a sphere):
