- Mute
- Permalink
- Report
as I set up cut of a sheet metal with 2d profile cutying.?
(Inventor HSM CAM )
(Inventor HSM CAM )
Hello @creocatia3d are you trying to use HSM to cut a 2D shape from a sheet metal plate?
You can RMB on the part face and export to .dxf which most cutting machines take, is there a specific need you have?
If you can embed an image of what your're trying to do or record a screencast showing where you're getting stuck that would be helpful.
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
it would not be something specific but rather a simulation of laser cutting on a planned plate.
From what you have said, you are just looking to see a simulation of laser cutting in Inventor. I have created a sheet metal nesting layout and then setup and run a laser cutting simulation of all parts as a demo. See the screencast below.
John Hackney, Retired
Last I checked this forum doesn't charge by the sentence...
Don't be afraid to construct thorough post in the future.
You will typically get much better help/assistance if you provide all the necessary details by fully defining your needs/question..
We can even use Google Translate if writing in English is preventing you from expressing your question better.. Go ahead and write in whatever your native language is..
Perfect!!!!
Thank´s!!!!
