Extrusion Properties are Changed when an Unrelated Sketch Dimension is Changed
I'm encountering a problem in which an extrusion that it referenced to a work plane is automatically ruined when I alter a line length in an unrelated sketch. I receive an error saying the extrusion distance is zero despite the extrusion being referenced to a work plane that is several inches away rather than referenced to a specific distance. Please see attached screenshots.
Cadmanto
But, is that line segment associated with the extrusion properties somehow?  Maybe through project geometry in the sketch?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
blair
Can you post the Inventor file, pictures don't tell the whole story
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
johnsonshiue
Hi! The error message indicates after you changed the dimension, the extrusion distance becomes zero. There must be some relationship between the distance and the dimension you changed. Please attach the file here. We are not good at guessing.
Many thanks!
Software Test Engineer
