Customizing the Marking Menu in the Measure command
BromanSillito
BromanSillito
Is there a way to customize the Marking menu for when you're in the Measure command? I'd like to be able to "Restart" with one click+swipe rather than right click, find it on the menu, then left click.
-niels-
There are no direct marking menu items for within the measure command, but you could set the measure command itself to a custom <ctrl + right click> menu.
You'd have to do this for each environment you'd want to use it in, but once it's set you can restart by holding down ctrl and swiping...
(you can set the individual types of measuring too, angle, loop, distance)
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
BromanSillito
Thanks! I guess I will have to request it in the idea station. It seems like a no-brainer when measuring to have a way to quickly Restart.
