Inventor 2018 Professional with all the latest updates...
I am creating Mepla pipes and fittings from scratch. I am using 0 engagement for the pipes, and engaging the fittings up to the flange. When I generate a routed system, like the one shown, the pipes do not engage at all onto the fittings. In my experience, a routed system should use the engagement of the fittings, ignoring that of the conduits, but not so here. What have I done wrong?
Hi @jessey9X6M8
Thanks for the part files and screenshot. You need to have Engagement on your Elbow, so the pipe sits over the groove, I measured 38 mm's, see below:
Cheers
Jon
Hi @jessey9X6M8
Cheers
Jon
Thank you for your reply. I don't think I understand. Is the left shot what you would propose for the authoring? Perhaps I should explain my choices.
I used "To Plane", rather than a measured distance because that distance will change when I move from one member of the family to another. Also, this distance does not allow use of a parameter, so I didn't see how to assign different distances for different family members.
I used female rather than male because I read that the tube and pipe environment tends to respect female engagement maximums more readily than male. I had used male, noticed this non-engagement issue, then switched to female.
Here is another element of weirdness:
If I put the fittings in using a T&P route, then it defaults to the pipe's 0 engagement and greys out the option to override.
If instead I insert the fitting into the assembly and just run pipes in the route, then I can override one end of the pipe, but not the other, to use the fitting's engagement setting:
FYI: I have minimum pipe increment set to .001 in, and the min engagement is 95% of max. There should be room for slop within those settings.
