custom name/label of same part inside assembly
JeroenLeemans4476
JeroenLeemans4476
Hi everybody,
I've searched and searched but cannot find the solution, or i'm looking with the wrong keywords.
So I hope somebody will understand my question 🙂
I'm used to work with AutoCAD, where I use blocks with attributes. So I can use the same block (part) with custom text.
I want to achieve the same result with Inventor 2018, and I've tried using iProperties but cannot find a proper way to do this.
I want to label my electrical circuit breakers and contacts, so that the labeling shows on every view I create/render I make/ 2d drawing I make/.....
Below you can see a photoshopped printscreen.
Currently my circuit breakers have a blank 'label', but I want to make some sort of custom property I need to fill in for each part so it will look like the first three breakers on my photoshop.
I do not want to make seperate files cause otherwise the BOM will not be correct.
So my question is, where can i make something that i need to fill in the name (Q1, Q2, .......whatever name it is) and that it will show on the location i want (in my case the white part you put the real label IRL)
mcgyvr
1-Use iparts.. Each differently labeled breaker is a different member of the ipart factory..
2-Make each label its own part number and set them to "reference" so they don't show up in the bom/parts list..
#2 is hands down the direction I would go..
Inventor really doesn't have the functionality for "instance level customization" often common with piping/electrical layouts,etc.. like that..
JeroenLeemans4476
Thanks for the reply.
#1 is a bit difficult cause i would have over 100 members
#2 is a good solution to keep the BOM, but to insert +100 labels each time in the assembly seems a bit time consuming for what it is.
Strange that a "stupid" program like AutoCAD can do it, but an intelligent program like Inventor can't.
Thanks again for the help 🙂
kind regards
Jeroen
