Change coordinates of a point
MichaelInneer
Message 1 of 10
MichaelInneer
How can I change coordinates of a point (not move) on a line for example from x20 y30 to x10 y0? Whatever I do, it just moves for some value.
Replies (9)
Message 2 of 10
JDMather
In Inventor - dimensions are your best friend (or should be).
Attach your *.ipt file here if you can't figure it out.
Message 3 of 10
johnsonshiue
Hi Michael,
You can add dimensions or constraints to a point so that it is locked in the place. You an also redefine the sketch coordinate system (finish sketch -> right-click on the sketch in the browser -> Edit Sketch Coordinate -> pick a point and a linear reference to relocate the coordinate system).
Many thanks!
Software Test Engineer
Message 4 of 10
lena.talkhina
Hello @MichaelInneer  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 5 of 10
MichaelInneer
Thanks for reply. But I meant some option to do it directly like in 3ds max. After max it really feels uncomfortable. Inventor doesn't seem to have such a feature.
Message 6 of 10
johnsonshiue
Hi Michael,
I think I know what you want now. You want to be able to redefine or move a point from A to B, right? Like I mentioned, Inventor geometry is associative. You need to use dimensions and constraints to control geometry.
Regarding move, there is indeed a way to do that too. In 2D Sketch, click on Move command -> select the point -> check "Precise Input" -> enter the X and Y movement -> select the base point.
Many thanks!
Message 7 of 10
tomasz.sztejka
>(...)You can add dimensions or constraints to a point so that it is locked in the place(...)
False. It is locked at specified DISTANCE from other geometry. And since there are plenty of possible solutions to it this point looks like locked only such long, as long the constraints solving system will not decide to select an another solution.
Message 8 of 10
johnsonshiue
Hi Tomasz,
Indeed, to lock a point on a sketch, you will need to ground it using Fixed constraint. Outside of a sketch, it will be a grounded workpoint.
Many thanks!
Message 9 of 10
tomasz.sztejka
Can I then enter the parametric equation for x and y coordinate and make it to follow change in parameters?
Message 10 of 10
johnsonshiue
Hi Tomasz,
Unfortunately, not. A fixed point stays in the space within the sketch. There isn't any other way to move it. I guess you may want to create a grounded workpoint or UCS. A UCS can be driven by three length parameters and three angular offset parameters. It is basically grounded until the parameters change. Then you can project the UCS origin to a sketch.
Many thanks!
