Long story short, we use a custom iProp as our "Part Number". I've created some iParts and within them I used iLogic to control the custom iProp.
SyntaxEditor Code Snippet
iProperties.Value("Custom", "Part Number") = iProperties.Value("Project", "Part Number")
it worked, or at least i thought it did until today when all the iParts are now shown with the same part number in the custom iProp. Anybody have a good way of making the Part Number column in the iPart pushing through to the custom iProp "Part Number" without having to copy/paste it over everytime.
Inv Prof 2014
SP 2 Update 7
Solved by Curtis_Waguespack. Go to Solution.
Hi Andrew_J_W,
You need to have the custom iProperty in your iPart table in order for it to be set differently for each iPart member. Do you have it set up that way?
I hope this helps.
Curtis
I do now, its just looks clunky due to the Member, Part Number (Default), Part Number (Custom) are all listed as the same thing. I wish I could collapse all three into one so I just have one instance of the part number itself.
Hi Andrew_J_W,
It might help to open the iPart table in Excel and set a formula to have 2 of the other columns reference the 3rd, so that there is a single place of entry.
I hope this helps.
Curtis
