Inventor Forum
Custom Content Center Content for Bolted Connection- Hammer Nuts
2 REPLIES 2
Jallen_USBattery
179 Views, 2 Replies
Hello All,
I am just starting out with custom content center items so forgive me for any ignorance here.
I am also starting to use a locally hosted Vault Basic platform
My objective is to setup 2 different sizes (2020 & 3030 series extrusion) Hammer Nuts and each one has 4 sizes of thread (M3/4/5/6). Then I want to be able to select the correct series & size when I am in an Assembly and use the Bolted Connection accelerator.
I've watched a few videos and perused the forum briefly but nothing seems to work quite right.
Where I am at:
I have an iPart/ModelState file for the 3030 item and I've attempted to Publish the item to the Content center but all of the Family Names & parameter tables has me a bit overwhelmed.
I figured I could just map the thread size and a custom iProperty for the Extrusion Series and be done but it doesn't appear that way...
Can someone point me in the right direction?
Also, I am attaching the .ipt for the file if that would be helpful.
2 REPLIES 2
Hello Jake,
your part is not iPart, it is just part with more model states. Unfortunately Content Center Publish does not support such model-states configuration part,  Content Centeter Publish process supports iPart only.
So to be able to publish, you need to convert all model states into iPart members and publish iPart.
FYI: Being able to use bolts / nuts in Bolted Connection, you need to authorize iPart before publish
Regards
Jan Priban
CGBenner
in reply to: Jallen_USBattery
@Jallen_USBattery
Take a look at this class from Autodesk University 2019 on Authoring & Publishing custom content.  Hopefully, it helps.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Technology Administrators
