Custom color appearance
lkirit2000
Advisor Advisor
lkirit2000
Hi Team,
Please see attached image. I created a custom color for both with same rgb number, why it looks differently?
admaiora
Can you attach the files?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
mcgyvr
@lkirit2000 wrote:
Hi Team,
Different lighting styles.
Lighting can have a drastic effect on how appearances look.
Go to view tab.. and make sure each file has the same lighting style set in this dropdown..
Or wait.. Are you talking about the clamp and the metal channel?
If so it looks like you might have different appearance "highlights/glossy" specs or different appearance types on those 2 parts..
As stated posting both parts here should allow us to spot the differences pretty easily.
lkirit2000
Hi
Thanks for your response.
How to adjust the gloss and highlight?
lkirit2000
Hi
In my case same lighting in all files, but looks differently?
ImogenWright
It is possible that you have two different appearances/materials on the different parts, this can make them appear different even if you use the same colour on both.
Check at the top of your screen for the items you want coloured the same and make sure they have the same appearance
Hope this helps 🙂
SBix26
I don't think there is any way for any of us to give a diagnosis with complete confidence without seeing the files themselves.  Zip them up and post them here.
Sam B
Inventor Pro 2023.1 | Windows 10 Home 21H2
