Inventor Forum
Custom border fill
3 REPLIES 3
GarySchmitz3154
297 Views, 3 Replies
Custom border fill
I am using a custom border within an IDW and from sheet to sheet the attribute information is hit and miss wether it is in the border or not. the only constants are date, sheet number, sheet number of  and author. the title, subject, company, and the project are missing sometimes. Does any one have any ideas for this paranormal activity
gary
Best Regards
Gary Schmitz
Dell Precision M3800
Core I7, 2.3GHZ, 16G Ram, Quadro K1100M 24In Monitor
Product Design Suite Premium 2016
3D Connexions Wireless
ProNest 2015
3 REPLIES 3
Hi! The flaky behavior does not sound right. Could you provide a repeatable example here or send it to me directly (johnson.shiue@autodesk.com)?
Thanks!
Software Test Engineer
What it sounds like your seeing in some is this :-
Whae you want to see this :-
Some of these are all iproperties from with in the IDW file, some like TITLE, PROJECT & PART NUMBER have to be entered manually in the IDW iproperties
then
followed by
Part No, Description & Project are all entered manually. The designer name is taken from the actual project (ipt) file, it can be altred at this stage, and the check mark placed for the date manually, these two will now always be there by default
Follow this by
In these options part no is carried forwards from the information that you previously entered, again some infraction has to be entered manually with dates being checked to be displayed.
Inventor 2025 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
The only internet access i had over the weekend was my phone.after 3 hours of expirementing and 1 crash I did discover the filling information comes from the properties of the IPT or the IAM. Another lesson from this is that the information is pulled from the first view model placed on the sheet. knowing this made it quicker to get the information in where it comes from.
Thanks for the time and effort
Best Regards
Gary
Best Regards
Gary Schmitz
ProNest 2015
