Hello everyone,
I would like to know if there is a way to set a custom default Bend radius in my pipe style.
At the moment, i have to set that radius every time i create a new route. It happen some times that i forget to change the value on 1 or 2 bends which is not great.
I know at the moment that the default radius is 2 times the nominal pipe size, and i would like to set a fixed value for every pipe size i use. Example: R1.312" for 0.75"nominal.
Thank you!
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Welcome to the community..
No this is not possible (but I will tag @cbenner to confirm). This is only possible if the style is bendable tubing or flex hosing.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous,
@Mark.Lancaster is correct. In rigid piping styles, the custom bends are created "on the fly" and cannot be set in your tube & pipe styles as defaults.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
