Inventor Forum
Cust. cont. c. part isn't in the Bolted C. Wizard after changing its Part Number
1 REPLY 1
289 Views, 1 Reply
Hey there,
I have created some custom families for DIN 934 nut. The main reason is the material. I have DIN 934 A2 and A4 families. By default, their Part Numbers do not have any explicit information so them are identical. This causes an issue in the Parts List, because Inventor confuses them and show them at the same line, with the same Part Number and with the Word "Varies" in description. Now, if I go to family table and enter an expression; "DIN 934 - "A4 " & {DESIGNATION}, then Bolted Connection Wizard is not able to find DIN 934 A4 (for example) family in the DIN section.
Thanks.
1 REPLY 1
kelly.young
in reply to: 20031995
Hello @20031995 if you can record a screencast to show what you are experiencing that would be helpful to give you more accurate suggestions. From the description I'm not sure of the workflow you are using or where the duplicate naming is causing problems.
Please select the Accept Solution button if a post solves your issue or answers your question.
Technology Administrators
