Hi, I am trying to sweep two "entrances" to a curved "tunnel" and am having trouble with interfacing correctly. There are two main trouble areas, one for each of the two entrances to the tunnel, as shown in the screenshots. I am trying to get a seamless surface for the two, but I am struggling to find the means how to do so.
I would greatly appreciate any suggestions. Feel free to edit and try it for yourself; the part is also attached.
PS. The lines are intentionally not tangential to the circular "walls"
Solved by JDMather. Go to Solution.
I am not at my Inventor machine to check your file, but from the images my first thought is to Shell a solid.
This is what I would suggest. I cant exactly tell what your trying to create here, lets call it a labyrinth? I would make the entire path in a 2d sketch (picture 1) then extrude it to what ever height is required (picture 2). Then to make the dome shaped top use the fillet tool to make those shapes Pic 3 . Then you can use the shell tool and make it you wall thickness, and delete the bottom face picture 4.
Did you mean it?
By the way - if you want to remove these excesses, just use the Delete Face command.
It doesn't know if you wanted to create this inner tunnel; I inferred this from the cutouts. I'm not sure of your intentions.
But all these methods work.
Kacper Suchomski
Of course.... Worked brilliantly thanks. I'm out of practice and it shows.
Thanks a lot!
