Inventor Forum
Curved surfaces not matching
5 REPLIES 5
karl.zammit.18
462 Views, 5 Replies
Hi, I am trying to sweep two "entrances" to a curved "tunnel" and am having trouble with interfacing correctly. There are two main trouble areas, one for each of the two entrances to the tunnel, as shown in the screenshots. I am trying to get a seamless surface for the two, but I am struggling to find the means how to do so.
I would greatly appreciate any suggestions. Feel free to edit and try it for yourself; the part is also attached.
PS. The lines are intentionally not tangential to the circular "walls"
5 REPLIES 5
JDMather
in reply to: karl.zammit.18
I am not at my Inventor machine to check your file, but from the images my first thought is to Shell a solid.
jmenier
This is what I would suggest. I cant exactly tell what your trying to create here, lets call it a labyrinth?  I would make the entire path in a 2d sketch (picture 1) then extrude it to what ever height is required (picture 2). Then to make the dome shaped top use the fillet tool to make those shapes Pic 3 . Then you can use the shell tool and make it you wall thickness, and delete the bottom face picture 4.
Construction Engineer, PE
Did you mean it?
By the way - if you want to remove these excesses, just use the Delete Face command.
It doesn't know if you wanted to create this inner tunnel; I inferred this from the cutouts. I'm not sure of your intentions.
But all these methods work.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
karl.zammit.18
in reply to: JDMather
Of course.... Worked brilliantly thanks. I'm out of practice and it shows.
Thanks a lot!
Thanks to all for your solutions. They all do the job!
Technology Administrators
