Cursor and marking menu are far appart
Message 1 of 24
When I try to access the RMB marking menu, the menu does not appear below the cursor but way off. This problem started with version 2020, before that I had never any problems. I am running Inventor 2019 as well on the same machine and the menu works fine there. I've got the latest software and drivers. This problem occurs in every environment (Part, Assembly, Sketch, Drawing). Strange thing is, the classic context menu works fine.
Replies (23)
Message 2 of 24
Mark.Lancaster
@Anonymous
First have you updated to Inventor 2020.1 and 2020.1.1?   Also make sure your video driver is up to date and don't rely on Windows telling you it is
If the above doesn't resolve the issue you may want to run the inventor reset utility from the Windows start menu/Autodesk/.Inventor 2020 section but before you do that you need to review this https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/How-t... and make sure to backup before performing the reset.
Mark Lancaster
Message 3 of 24
Yes, all the latest updates are installed. Graphics driver is installed manually. Reset and even re-installing does not help.
Message 4 of 24
johnsonshiue
Hi Andrew,
Please share your screen resolution and DPI setting. Do you use two monitors?
Many thanks!
Software Test Engineer
Message 5 of 24
My screen resolution is 3840 x 2160, scaling 150%
I use one monitor only.
Tried different settings with no success.
Inventor 2019 works perfectly but 2020 does not.
Message 6 of 24
Has nobody a suggestion?
Message 7 of 24
johnsonshiue
Hi Andrew,
Did you try using Inventor Reset Utility like Mark suggested (All Programs -> Autodesk -> Inventor 2020 -> Tools -> Inventor Reset Utility)? It will help reset all settings back to install default.
Many thanks!
Message 8 of 24
Yes, I did that (more than once). I even uninstalled and reinstalled, also more than once. No matter what I try, the result is always the same. I am totally at a loss here, any help highly appreciated.
Message 9 of 24
JarFu
@Anonymous did you use dual monitors when run Inventor?
There are two known issues related dual monitors:
1. Right click on Inventor in second monitor but Marking Menu may show the primary monitor wrongly when use different DPI settings for two displayers
2. Marking menu is always leave in the primary monitor if connect second monitor after run Inventor to open files, this happens even with same DPI settings for two displayers
Jar Fu
SW Engineer
Inventor QA
Message 10 of 24
Sorry, I have only a single monitor.
Message 11 of 24
HelmesHe
@Anonymous , does this also exist when scaling is other than 150%, such as 100%? Which version of Windows 10 do you have? You could find it with Win+R and typing "winver".
One solution you could try is to switch "Let Windows try to fix apps so they're not blurry" in "Advanced scaling settings".
Another is to right click "Inventor.exe" in the bin folder and open "Properties". Then click "Change high DPI settings" in "Compatibility" tab and try different settings.
Helmes He
Senior Software Engineer
Message 12 of 24
I am using the latest version of Windows 1909 (OS Built 18363.535)
"Let Windows try to fix apps" is already set.
When I use a scaling of 100%, everything is fine but the menu size is obviously too small. Changing the scaling back to 150%, the problem resumes.
If I change the properties of "Change high DPI settings" - Scaling override performed by "System" the menu appears were it is supposed to be but now the text and icons in the application are quite fuzzy, hard on the eyes, which is not acceptable.
Message 13 of 24
nzlanderURY89
I've got the same issue with Inventor 2021. Is there no better workaround than changing the DPI scaling behavior? It looks like that Inventor is not recognizing the screen resolution. Maybe we can tweak the registry?
Message 14 of 24
HelmesHe
I guess this is a Qt issue of supporting high DPI. Could you please help try setting either or both of the following two environment variables?
  1. "QT_AUTO_SCREEN_SCALE_FACTOR" as 0 or 1, which enables/disables automatic scaling.
  2. "QT_SCALE_FACTOR" as 1 or other values, which defines a scale factor for Qt windows.
Helmes He
Message 15 of 24
nzlanderURY89
You just made my day! That was exactly what caused the problem. Thank you very much!
Message 16 of 24
HelmesHe
@nzlanderURY89, glad to know it works. Could you please tell us which environment variable you tried setting with which value? So in the future release, we could fix it without having to set the environment variables.
Helmes He
Message 17 of 24
nzlanderURY89
Hi HelmesHe,
I've set QT_AUTO_SCREEN_SCALE_FACTOR to 0
Thanks again for your help.
Message 18 of 24
HelmesHe
Thanks for sharing the information. That's helpful.
Helmes He
Message 19 of 24
Landrie4586
Observer
Observer
How exactly do you change those variables? I'm having this issue as well and reinstalling it several times has done nothing.
Message 20 of 24
SBix26
Assuming you're using Windows 10, in Windows Settings, search for Advanced System Settings.  In the resulting System Properties dialog, click on Environment Variables...; in the System variables section, click New and fill in the name and value of the variable you're creating.  Note that you must have Administrator privileges on your system in order to set system environment variables.
Sam B
Inventor Pro 2021.2.1 | Windows 10 Home 2004
LinkedIn
