Creation algorithm using the frame generator
89198826955
Message 1 of 13
89198826955
Good afternoon! I constantly encounter unusual work of the frame generator. Maybe I'm doing it wrong? And I have some questions
1. If I make an array, then I do not have the ability to change the profile using the frame generator.
2. even if I put three dependencies and the part is fully defined, the array of these parts is not fully defined
3. subject to the correct arrangement of parts, the change leads to unpredictable actions and the destruction of the connection.  In the nested assembly file I put an example it has a variable parameter "height".  if I change it to the big side it is rebuilt well, if the structure collapses to the small side. After reading the forum, I saw many different answers to these questions, but did not understand the "correct" construction technology. The question is how to build it most "correctly"? For example:
1. it is correct to make an array at the sketch level or vice versa to make an array at the detail level.
2 I saw this method: make micro-holes and make dependencies with them, and suppress them when printing a part As an answer, I would like to receive an algorithm for the correct solution.
Replies (12)
Message 2 of 13
johnsonshiue
Hi! Are you talking about the alignment? The frame members may rotate around the reference sketch in 3D, leading to unpredictable behavior. To ensure proper alignment, right-click on each member -> Align -> select a piece of static planar or axial geometry in the assembly.
Many thanks!
Software Test Engineer
Message 3 of 13
89198826955
It's here?
Did I understand correctly?
Message 4 of 13
89198826955
one element is fully defined (black dot)
array of elements not fully defined (white dot)
now if I attach a corner to the plane of the part using the frame generator, then the behavior will be unpredictable
because the part plane is not fully defined
Question: how to do it right? what algorithm?
abandon the array and arrange all the elements manually?
add dependencies to each element of the array separately?
or is there another option?
Message 5 of 13
89198826955
If you make a dependency for array elements
there is an excessive dependency
Message 6 of 13
cadman777
For your simple structure, I would NOT use FrameGenerator.
Instead, I would make a MasterSketch and Derive it into each part.
Then insert each part into the assembly/weldment at the WorldOrigin and make them Grounded.
Then array the parts in the assembly as desired.
When using FrameGenerator, I rarely use arrays of parts.
Mostly I do it on railing pickets b/c they are so repetitive, and sometimes on railing posts when the railing weldment is a long run with many pickets on the same ground level.
Short story: Once I had to design a drilling rig (it's a 100' high tower with trusses on 3 sides and open on one side). I tried making it in the FrameGenerator and it BOMBED! In other words, the FrameGenerator model sucked up computing resources so it slowed down the whole project. That was my lesson in NEVER USE FG TO DO COMPLEX WELDMENTS! So from that point on (that was in the early 2000's) I make simple and complex weldments with a MasterSketch which is derived into the part, and use a Block of the structural profile inside each part. Then make end treatments using WorkFeatures based on the MasterSketch. There's a LOT of flexibility when using BASIC Inventor.
So if I was making that simple frame (looks like 5 or six 'custom' parts instead of 17+ parts using FG), I would NOT us the FG.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 7 of 13
johnsonshiue
Hi! Yes, that is the Align command I was talking about.
Many thanks!
Message 8 of 13
89198826955
So the best solution would be to abandon the frame generator and create a multi-body part?
Create a frame profile --- autocad blocks -- or draw it yourself?
Message 9 of 13
89198826955
Really want to get a build file using a frame generator from professionals to analyze the build
Message 10 of 13
cadman777
OK, I get it. So you want to do the FrameAnalysis, that's why you're using the FG.
I think you can make it yourself and use FEA Analysis on it.
Let me take time tomorrow to throw one together for an example for you to see what I mean.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 11 of 13
89198826955
No, not for frame analysis
to analyze the construction method
Message 12 of 13
89198826955
The construction algorithm is necessary for me for training
b.mccarthy showed me the algorithm for building from sheet metal
Now building this takes 15 minutes)))
Message 13 of 13
89198826955
On the advice of Johnson Shiue, I completely defined the part (black dot) and snapped the angle to the plane of the part
everything works great
when changing the height of the structure, the assembly behaves correctly
if i add an array of details
details not fully defined (white dot)
and assembly behaves misbehaves
when i change the height of the structure only the first part is always in the right position
