Creating splines through points
Moorejac004
Message 1 of 11
Moorejac004
Hi I have a drawing that has around 9,000 points. I need to connect a spline to all of the points, is there anyway for the program to create the spline without me having to go through each point individually.
Accepted solutions (3)
Replies (10)
Message 2 of 11
Gabriel_Watson
In the past this has not been possible (to do so automatically/faster than selecting each point individually), but in the discussions the general idea is that you can reduce the sample to less points and still keep some small deviation:
https://forums.autodesk.com/t5/inventor-forum/create-a-spline-with-given-points/td-p/4600487
https://www.reddit.com/r/AutodeskInventor/comments/9xfpzy/creating_a_spline_from_imported_3d_points/
Message 3 of 11
Gabriel_Watson
Actually, I just found an external app here that might do the trick for you, to import coordinates from Excel automatically:
https://www.cadstudio.cz/en/apps/importcoord/
Message 4 of 11
johnsonshiue
Hi! If the point coordinates (2D or 3D) are stored in an Excel spreadsheet, you can import the points and have lines or splines created accordingly. This workflow has been available for years. Start a new 2D or 3D sketch -> Import Points -> pick the Excel spreadsheet.
Many thanks!
Software Test Engineer
Message 5 of 11
HenkdeB
I can import the points, but what is the command to automatically create the Spline through these point?
Message 6 of 11
HenkdeB
Found it
Message 7 of 11
iquacker
Please, please share!
what is the command?
Message 8 of 11
Alexander_Chernikov
Hi!
When you are in the 2D/3D sketch environment
1. Select "Points"
2. Find the Excel file
3. Press the "Options" button additionally
4. Select the import type (spline)
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 9 of 11
iquacker
Hi!
Thank you very much for your very well explained effort here! Unfortunately, because I'm new here and very frustrated by my failed attempts, I didn't realize that my search would bring me to the Inventor forum instead of the Fusion 360. 360 has no such choices. So I've contacted Fusion support, thrown the problem in their laps and are hoping for the best.
Best regards -
Message 10 of 11
iquacker
Hi!
Thank you very much for your very well explained effort here! Unfortunately, because I'm new here and very frustrated by my failed attempts, I didn't realize that my search would bring me to the Inventor forum instead of the Fusion 360. 360 has no such choices. So I've contacted Fusion support, thrown the problem in their laps and are hoping for something to happen.
Best regards -
Message 11 of 11
kacper.suchomski
You can report your need in the Idea Station portal for Fusion.
You can also search for extensions in the AppStore. Eg:
https://apps.autodesk.com/FUSION/pl/Detail/Index?id=3044478757760121899&appLang=en&os=Mac
https://apps.autodesk.com/FUSION/pl/Detail/Index?id=3336491865802949642&appLang=en&os=Win64
If there is no such function, then technical support will not conjure it up.
Kacper Suchomski
