Creating hull but ignoring some solid ?
Hi everyone !
So I've got myself those two shapes, and I want to make a hull out of the big one while ignoring the small one so it looks like this :
in the inside. I tried :
- doing something with this little thingy :
but it tells me there should be at least 2 solids.
- doing something with that little thingy :
But I can't select any surface or tool. Is there any easy whay to do something like that ?
Thanks in advance !
Replies (7)
johnsonshiue
Hi! This should be doable easily. Please share the file here.
Many thanks!
Software Test Engineer
Here
JDMather
See Attached file.
You should fully define your sketches.
Still gives me something like this:
Or this :
when I try to "empty it out"
Instead of this :
I get this :
Or this :
JDMather
Oops, I must have Attached the wrong file - back in a few minutes.
@Anonymous
Try this one...
johnsonshiue
Hi! There are several ways to do that. One way is to create the features in a different order. You can delete the boxy extrusion and create shell first. Then add the extrusion.
Another way is to use Delete Face feature (check Heal option) -> pick the inner shelled faces of the boxy extrusion.
Many thanks!
Thanks everyone !
