Creating hull but ignoring some solid ?
Message 1 of 8
Hi everyone !
So I've got myself those two shapes, and I want to make a hull out of the big one while ignoring the small one so it looks like this :
in the inside. I tried :
- doing something with this little thingy :
but it tells me there should be at least 2 solids.
- doing something with that little thingy :
But I can't select any surface or tool. Is there any easy whay to do something like that ?
Thanks in advance !
Replies (7)
Message 2 of 8
johnsonshiue
Hi! This should be doable easily. Please share the file here.
Many thanks!
Software Test Engineer
Message 3 of 8
Here
Message 4 of 8
JDMather
See Attached file.
You should fully define your sketches.
Message 5 of 8
Still gives me something like this:
Or this :
when I try to "empty it out"
Instead of this :
I get this :
Or this :
Message 6 of 8
JDMather
Oops, I must have Attached the wrong file - back in a few minutes.
@Anonymous
Try this one...
Message 7 of 8
johnsonshiue
Hi! There are several ways to do that. One way is to create the features in a different order. You can delete the boxy extrusion and create shell first. Then add the extrusion.
Another way is to use Delete Face feature (check Heal option) -> pick the inner shelled faces of the boxy extrusion.
Many thanks!
Message 8 of 8
Thanks everyone !
