I'm trying to get the word out about a particular IdeaStation feature request regarding iParts, so I'm scouring the forums for threads like this one which touch on the weaknesses of iParts.
Part configurations are a common and important element in professional 3D drafting, used to communicate different geometry configurations and machinging stages of a part. They should be very simple to work with, but Inventor has several critical weaknessess which make working with part configurations very cumbersome. The following IdeaStation Feature Request suggests four enhancements to help iParts reach their full potential.
Below is a reproduction of the IdeaStation post. If you think these suggestions would be effective enhancements, please click the link below and cast a Kudo. The more votes it receives, the more priority Autodesk will likely give to makeing these game-changing improvements. Thank you!
Reproduction of IdeaStation post:
Suggested improvements:
1. For iParts, store the iPart and its members in a single file.
…rather than a separate file for each member.
2. Keep the Material and iProperties in sync.
For iParts, keep the Material and iProperties in sync between all iPart members unless the properties are specifically added to the iPart table. For Derived Parts, optionally derive the material from the Master [source] file (this also necessitates being able to assign a material to each body in a multi-body part)
3. Include Work Features for use at Assembly level.
In iParts, include Work Features in all members unless the features are specifically added to the iPart table. In Derived Parts, include Work Features in the part itself, not within the Base feature where they are only accessible when the Assembly Browser is in Modeling View.
4. Make Feature Patterns in iParts and Derived Parts accessible to Assemblies.
This way Feature Patterns in iParts and Derived Parts can be used to drive associative Component Patterns in Assemblies.
Click here to view the IdeaStation thread and cast a Kudo!
