Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a trick to creating a plane that is tangent to a surface, and normal to an axis.
I have imported geometry, that has a hole through a curved surface. In Solidworks, I would select the surface and axis, and it would create a plane that is normal to the axis and tangent to the curved curved surface (assuming it was not a spline). This process couldn't be any simpler.
In Inventor, the closest I can get is using the Normal to Axis through Point. This gives a preview of what I want, but then gives the super helpful error message ...
Any help would be appreciated, thanks.
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
iParts = iHeadache
