Creating a new sub-assembly within an assembly
Message 1 of 8
In Solidworks, if you insert some components into an assembly, you can select them in the tree, right click and choose "Create new subassembly here" (or something simiar) and it will create a subassembly of the parts, within the main assembly.
As per image below.  I think Parts C and D need to be constrained only to each other and Part B, not to anything in the main assembly but I can't remember for sure.
Is there an equivalent command in Inventor?
Replies (7)
Message 2 of 8
t_hascj
Try Demote command.
Right click -> Component -> Demote
Jaroslav
Message 3 of 8
-niels-
As Jaroslav mentioned, Demote should do what you want.
http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-47D36B2B-F347-4B24-BAD5-6360DBE5458F
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 4 of 8
mdavis22569
Demote ...but MAKE SURE YOU HIT SAVE ....
you'll need to save the main assembly file ...so you can save the new sub-assembly file in it.
You'll be asked to to do an Initial Save in the pop up box
Mike Davis
Message 5 of 8
Thank you all for the replies.  That's great.
I see in the video in the dialogue box where you create the new subassembly it refers to it as an in-place "component".  By "component", does it mean subassembly?  I.e. a subassembly that once saved could be inserted into another assembly, and has no link to the original parent assembly in which it was created?
Many thanks again
Message 6 of 8
mdavis22569
Correct ... it's what Inventor just calls it ...
You'll keep almost all constraints too ... if something is set up in the Main assembly it won't transfer to the sub, but if 2 parts in the sub assembly are constrainted together, they will transfer into the new sub assembly you setup.
I really like the Demote/Promote command. I think it's one of those commands/tools that could be used more if people knew more about it ...
Mike Davis
Message 7 of 8
Thanks again.
Yeah, it's really handy.  I'm using it to model a frame to support a pipework system.  It allows me to build the frame within the main assembly, so I can make sure all the supports are in the right place in relation to the pipework, then I can end up with the frame as its own subassembly.
The main component of the frame located in the main assembly with three constraints, and then all subsequent components of the frame are constained only to other components of the frame, and not to the main assembly.
Message 8 of 8
Jonathan.Mantis
Observer
Observer
It's probably not used because "demote" is a terrible name for what the command is actually doing. Not intuitive at all. "Create subassembly from parts" is the intent, so that's what the name of the command should be.
