SOLID BODY MANAGEMENT
After some help with multi solid parts if possible.
I have a complex multi body part (100+), which i will use to drive an assembly that i will later create. As it turns out, some of the pieces are actually identical. When it comes to doing the drawing, parts list etc.. these will need to appear with the same part number, parts list entry etc...
How do people generally handle this when they create their assembly from a multi body part?
I guess i could create all the solid bodies, and then later on replace any that are duplicates. Seems a messy way of doing things, and it would be easy to end with part numbers out of sequence (ie. gaps where duplicate parts have been replaced).
Thanks in advance
