Creating a flat pattern from a loft
Message 1 of 25
I can't make a flat pattern from a loft.
First of all, I did get a model (11951-222505_022.ipt), but I don't know it's extension, but Inventor is opening it (and i did save it in .ipt), then I wanted to make a flat pattern from that weird model, but it didn't work, so I did tried to make myself one, simillar (Part4)
First I made a sketch, then another sketch, lofted it and that's it. What am I doing wrong?
Replies (24)
Message 2 of 25
kennyj
Hello!
Without opening your files I am going to assume several things:
1) that you didn't shell or make the part hollow / have thickness?
2) that you didn't set your sheet metal thickness default to match the actual model thickness exactly?
3) that you did not Rip a seam for Inventor to know where to start/stop the fold  (If you fold this out of paper, where do the paper's outside edges meet? Did you show this on your model?)
Take a look at this video and see if it helps:
https://www.youtube.com/watch?v=p5Qm-MQBQng
Hope that helps,
Kenny
Message 3 of 25
salariua
@Anonymous wrote:
Hello!
@Anonymous you have a couple of issues to fix before following @kennyj 's advice.
original model (11951-222505_022.ipt) has a thickness of "27.806619754 mm"
new model (Part4.ipt) has a thickness of "36.587634256 mm" and rule set to "40mm"
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 4 of 25
salariua
@Anonymous it does work ... Take a look at my attachment and repair the end cut. I don't' have time to properly fix it but this will get you in going in the right direction.
Adrian S.
blog.ads-sol.com
Message 5 of 25
JDMather
@salariua
iProperties indicate Inventor 2013.
Message 6 of 25
JDMather
@Anonymous
You can simplify your sketches as single arcs.
Then use the sheet metal Lofted Flange tool rather than standard Loft tool.
Be sure to set the Output to Die Formed.
Message 7 of 25
salariua
my bad... should have checked, thanks for that @JDMather
Adrian S.
blog.ads-sol.com
Message 8 of 25
The problem is that these are not both arcs, one is an arc (element no. 2 - see picture 1) and one is a kicked elipse (element no. 1 - see picture 1)
These are steps I did:
1. Open a model.
2. Made a drawing, after that a section - to see these funny elipse (element no. 1 - see attached pic 1).
3. Make a sketch on .idw, project this elipse on sketch to copy it and  finally copy it.
4. I did open a new part, make a sketch and paste this copied elipse.
5. Inventor consider it as a spline.
6. I made a second sketch, on the offsetted plane - circle shape (element no. 2 - see attached pic 1)
7. Lofted flange does not see the profiles.
Part 1: My new sketches.
Model: Basic model from which I want to copy the shape of this elipse.
All I want is to make a flat pattern of a element no. 3 - see picture 2, including a triangles.
Message 9 of 25
A misssing PICTURE 2
Message 10 of 25
Message 11 of 25
salariua
Let's try this again. Are you trying to get flat pattern of this part?
EDIT:
is this what you're after:
Adrian S.
blog.ads-sol.com
Message 12 of 25
Yes, I want to try make a flat pattern of that part. But I can't for instance convert it to sheet metal.
There is an error: "This model cannot be converted to Sheet Metal because it contains features that have created multiple bodies. In order to convert to Sheet Metal these features must first be removed".
I wanted to isolate this part, but my Inventor can see it only with connection to pipe.
I can see a Thicken1 option in your browser, you first apply a thickness and then in sheet metal defaults you set this thickness to make a proper flat pattern?
@salariua
Message 13 of 25
S_May
Hi @Anonymous,
Message 14 of 25
salariua
@Anonymous I have indeed used copy on the inside surface and then thicken the quilt to a measured thickness of your model.
I don't have access to 2013 here and I won't for a couple of hours but I will do a screencast in 2015 and hope it's close enough for you to follow in 2013
Ideally, you would want to derive the model into separate parts and not use copy as I did just so that all the parts update when the original model changes but it might not be the case here, seems to be a one off.
See this video here
Adrian S.
blog.ads-sol.com
Message 15 of 25
It works, thank you very very much!:)
Have a good day!
Best regards
MRumin
@salariua
Message 16 of 25
Fletcher_Apel
Observer
Observer
Hi @MRumin
Thanks for the video it was great, I tried a few methods including exactly as you showed however I am still stuck. I want to produce fabrication plans for a lofted chute going form a 1400 x 400 mm rectangle to a 250mm dia circle, with a 10mm wall. I have tried to complete this as 1 part, 2 parts, and for part and it never flattens out.
Fletcher
Message 17 of 25
JDMather
@Fletcher_Apel
You have replied to an ancient thread.
Attach the *.ipt file of your attempt and indicate what version of Inventor you are using.
Did you include a rip in your profiles?
Message 18 of 25
Fletcher_Apel
Observer
Observer
I'm on 2021, I have attached the files
Message 19 of 25
kennyj
Please start your own post with proper title and tags so others can help you (and get the same help if they have the same question after you figure it out).  Thank you.
Message 20 of 25
JDMather
See Attached possible solutions.
In the file that you attached - you did not use Sheet Metal tools.
Your Sketch2 was unconstrained?
