Creating a flat pattern from a loft
Message 1 of 25
I can't make a flat pattern from a loft.
First of all, I did get a model (11951-222505_022.ipt), but I don't know it's extension, but Inventor is opening it (and i did save it in .ipt), then I wanted to make a flat pattern from that weird model, but it didn't work, so I did tried to make myself one, simillar (Part4)
First I made a sketch, then another sketch, lofted it and that's it. What am I doing wrong?
Replies (24)
Message 21 of 25
Fletcher_Apel
Observer
Observer
Many thanks for this help!
I was overlooking the lofted flange tool
Message 22 of 25
thomas.vanhaecke
I see this problem has accured with other people.
I have the same question, but i can't seem to make a flat pattern to a part.
Can someone help me with this please?
In attachement you can find the ipt file where i wqnt to have a flat pattern.
Plate thickness should be 5mm.
Thanks in advance
Message 23 of 25
JDMather
@thomas.vanhaecke
You have use Loft when you should have used Lofted Flange (a sheet metal tool).
These are two different tools...
Message 24 of 25
thomas.vanhaecke
@JDMather ,
I have tried this, but the result is not the same as i use normal loft.
See in attached the file with loft and the file with lofted flange.
I can't seem to get it right.
Can you give me some tips ore show how i can make this in lofted flange please?
Ore maybe see what i am doing wrong in part "AALHMOB_80"
Thanks in advance.
Message 25 of 25
JDMather
@thomas.vanhaecke
Your part is twisted (not cylindrical or conic bend).  If you can't work around the Lofted Flange "solution" then perhaps Unwrap of the Lofted solution.
