- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I found a youtube video on how to create a coil along a path (for example - a telephone cord). It was easy to create the part, however it took some experimenting to get a solid surface and turn of the inital sweep to remove the geometry required to create the actual coil. The coil was inserted into an assembly (essentially a conduit for electrical wiring) without a problem. However, when I put the assembly into a drawing file, the original geometry returns (yellow image in pdf) and the option to turn if off is greyed out.
Can this be fixed and if so how?
Link copied
