Inventor Forum
Creating a coil along a path
4 REPLIES 4
JoelMckone
278 Views, 4 Replies
I found a youtube video on how to create a coil along a path (for example - a telephone cord).  It was easy to create the part, however it took some experimenting to get a solid surface and turn of the inital sweep to remove the geometry required to create the actual coil.  The coil was inserted into an assembly (essentially a conduit for electrical wiring) without a problem.  However, when I put the assembly into a drawing file, the original geometry returns (yellow image in pdf) and the option to turn if off is greyed out.
Can this be fixed and if so how?
Tags (3)
Labels (1)
4 REPLIES 4
SBix26
in reply to: JoelMckone
Can you post the assembly, other components, and drawing files?  I can't replicate your results with the templates I have.
As always, it's important to let forum readers know what version of Inventor you're working with-- I found that your part file is 2024 format.
Sam B
Inventor Pro 2024.2 | Windows 10 Home 22H2
johnsonshiue
Hi! I guess the drawing view has "Associative" design view option turned on. Edit the drawing view -> uncheck the Associative. Then you should be able to make the surface bodies invisible in the shaded drawing view.
Many thanks!
Software Test Engineer
Are surface body views disabled in the model?
Is the visibility of surface bodies disabled in the drawing?
https://youtu.be/a7Y9wr_vfIw?feature=shared
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
JoelMckone
in reply to: johnsonshiue
Thanks for the tip - the 'Associative" design view was turned off, however I changed the Design View from 'default' to 'primary' which solved the problem.  It would probably been a while before I thought to check the drawing view settings as I was  focused on the making changes in the browser.
Technology Administrators
