Hi all! I am atemping to creat the bottom portion of a canoe. I imported the points for the canoe geometry and lofted the 3D sketches to create a conoe solid. From there I used a 2D sketch to create the "mold" of the bottom of the canoe. My first action was to try to use the shell tool to carve out the shape I need. I couldn't get that to work so my next attempt was to use the carving tool but that also didn't yeild any results. Is there any way I can carve this created shape out or are there more steps I need to do? Thanks!
I am using Inventor 2016 for reference.
Solved by Marco.Takx. Go to Solution.
http://www.widom-assoc.com/derived_parts2.pdf
