I don't understand it......sometimes I am able to create a 3D PDF, but sometimes I get the following message (attached) - and no PDF!
Anyone got any ideas?
Solved by bob_holland. Go to Solution.
An update:
To see whether it was an issue with my assy, I created a new very simpe assy and tried to 3D pdf that - it worked.
So then i tried to simplify the original by using shrinkwrap. I tried to 3D PDF it, no joy.
So....would i be correct in assuming it is an issue witth my assy, not the pdf function?
HI @bengee5454
Can you share it with me, and I'll look it over
how shall I send it - not sure the company would want this being made public! email?
you can get me on my website or A360
You can use A360 / Wetransfer and I'll do it all privately after in email...
I have sen an email to the address on the website.
Please excuse the rubbish filenames - its still very much WIP!
Thanks.
After a quick investigation, I believe the problem lies with the attached.
Can anyone confirm this?
Whats the issue here?
thanks
Didn't get anything,
try support@yourcad.guru
however that IPT worked for me:
I won't show it all
both views ...
Hi! What Inventor build are you on?
Many thanks!
hi Johnson
here's a screensnot of the About splash screen:
Does this tell you what you need?
You're at out of the Box version currently ..
You will need the new templates probably from the 2017 update:
Hi! You are on 2017 RTM build without any updates. Could you apply 2017.4 (or R4) Update? I believe the issue should be resolved.
Many thanks!
Shouldn't he get the new templates too ...to be safe?
Hi Mike,
Yes, it would be great if he pulls down the new template files also. I could be wrong but the error dialog should not be related to template files. Anyway, it is better to get the latest update and the updated template files.
Many thanks!
i can see he 2017.1.1 Hot Fix, bbut no 2017.4, or R4.
Where can i get these updates?
Here is a link to the updates:
If you want to use the Autodesk Desktop App, you may need to reinstall it:
Please try this and let us know it the updates resolve your issue.
Thank you.
I can report that after applying the update, and loading the templates, 3D PDF function is working!
Many thanks to everyone who got involved with this issue.
Glad the updates helped get you back on track ....
