Inventor Forum
Creating 3D PDF issue
19 REPLIES 19
Message 1 of 20
bengee5454
938 Views, 19 Replies
I don't understand it......sometimes I am able to create a 3D PDF, but sometimes I get the following message (attached) - and no PDF!
Anyone got any ideas?
19 REPLIES 19
Message 2 of 20
bengee5454
in reply to: bengee5454
An update:
To see whether it was an issue with my assy, I created a new very simpe assy and tried to 3D pdf that - it worked.
So then i tried to simplify the original by using shrinkwrap. I tried to 3D PDF it, no joy.
So....would i be correct in assuming it is an issue witth my assy, not the pdf function?
Message 3 of 20
mdavis22569
HI @bengee5454
Can you share it with me, and I'll look it over
Mike Davis
Message 4 of 20
bengee5454
in reply to: mdavis22569
how shall I send it - not sure the company would want this being made public! email?
Message 5 of 20
mdavis22569
you can get me on my website or A360
You can use A360 / Wetransfer and I'll do it all privately after in email...
Mike Davis
Message 6 of 20
bengee5454
I have sen an email to the address on the website.
Thanks.
Message 7 of 20
bengee5454
Please excuse the rubbish filenames - its still very much WIP!
Thanks.
Message 8 of 20
bengee5454
After a quick investigation, I believe the problem lies with the attached.
Can anyone confirm this?
Whats the issue here?
thanks
Message 9 of 20
mdavis22569
Didn't get anything,
try support@yourcad.guru
 however that IPT worked for me:
I won't show it all
both views ...
Mike Davis
Message 10 of 20
johnsonshiue
Hi! What Inventor build are you on?
Many thanks!
Software Test Engineer
Message 11 of 20
bengee5454
in reply to: johnsonshiue
hi Johnson
here's a screensnot of the About splash screen:
Does this tell you what you need?
Message 12 of 20
mdavis22569
You're at out of the Box version currently ..
You will need the new templates probably from the 2017 update:
https://knowledge.autodesk.com/search-result/caas/downloads/content/inventor-2017-language-packs.htm...
Mike Davis
Message 13 of 20
johnsonshiue
Hi! You are on 2017 RTM build without any updates. Could you apply 2017.4 (or R4) Update? I believe the issue should be resolved.
Many thanks!
Message 14 of 20
mdavis22569
@johnsonshiue
Shouldn't he get the new templates too ...to be safe?
Mike Davis
Message 15 of 20
johnsonshiue
Hi Mike,
Yes, it would be great if he pulls down the new template files also. I could be wrong but the error dialog should not be related to template files. Anyway, it is better to get the latest update and the updated template files.
Many thanks!
Message 16 of 20
bengee5454
Thank you for your inputs.
I shall update the template files tomorrow  and let you know the result.
Message 17 of 20
bengee5454
i can see he 2017.1.1 Hot Fix, bbut no 2017.4, or R4.
Where can i get these updates?
Message 18 of 20
bob_holland
@bengee5454
Here is a link to the updates:
https://knowledge.autodesk.com/search-result/caas/downloads/content/inventor-2017-updates-for-custom...
If you want to use the Autodesk Desktop App, you may need to reinstall it:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/About-Autodesk-desktop-a...
Please try this and let us know it the updates resolve your issue.
Thank you.
Bob Holland
Autodesk Product Support
Message 19 of 20
bengee5454
in reply to: bob_holland
I can report that after applying the update, and loading the templates, 3D PDF function is working!
Many thanks to everyone who got involved with this issue.Smiley Happy
Message 20 of 20
mdavis22569
Glad the updates helped get you back on track ....
Mike Davis
