Been using the Cable-Wire harness function for several releases now. After upgrading to 2018 when trying to create the wire table in the cable drawing, I get the following error:
This wasn't an issue in the past. I can import a Parts List table no problem.
I originally thought it was because the Table report may be out of date, updated it, same issue.
I am running Microsoft Office Professional 2013.
I have tried the Autodesk reset tool several times, same issue.
I have completely Uninstalled the entire Autodesk suite, rebooted computer, downloaded the latest version from Autodesk website, installed it, rebooted computer, let the updater update Inventor both service packs. Rebooted computer again. Same issue.
This is a brand new drawing. I opened a previously done drawing with it's wire table in the drawing, tried to Create the table from the existing csv file, same error.
This picture shows what excel looks like prior to running the create table command.
This command shows Excel after running the Create Table command.
It looks like there is some type of hang-up happening.
Suggestions???
I think I have found a work-around.
1. After creating the wire table from the Inventor assembly.
2. Open the wire table CSV file in Excel as a comma delimited file
3. Save file as Excel worksheet
4. Open Nailboard drawing and use the Create Table command, choose the Excel file.
@jesscadd The error seems to indicate a problem registering Excel properly with Inventor..
I would be cautious of marking your post as solved in case there is a real bug going on that won't get fixed if they don't know about it..
If that message comes up again when you try to create a new drawing with a new table then its not solved for sure..
But if that process somehow managed to trick Inventor into properly registering it and its not happening anymore for new drawings,etc... then ok..
The strange thing is there is no issue bringing in the Parts List table or Revision table. It is just the Create Table from the Nailboard drawing tab.
Hi Jessica,
Are you able to create an iPart? If not, it means the link between Inventor and Excel is totally broken.
Many thanks!
Johnson,
The name is Kirk not Jessica. I opened an existing table and added additional parts, no problems saving the files. Everything shows correctly. Like I said the main issue seems to be within the cable functionality.
Hi Kirk,
I am sorry to get your name incorrectly. I thought the id looked familiar with another user. Sorry about that! It sounds like the issue is specific to Cable and Harness report, not general Excel workflow failure. I will work with the project team to understand the behavior better.
Many thanks!
on one my PC I have trouble with Excel as well, so I would like to know/help you. Could you let me know if you can create iPart - iPart workflow iteracts with Excel as well (or in the Content Center Editor edit family table via Excel) - I would like to know if your issue is related to Cable & Harness or interaction Inventor -> Excel.
Thank you
Jan Priban
Autodesk Content Center team
OK, I can open iPart as well, but please add new row/member to iPart table. Does it work? For me not, I am getting
Jan Priban
