when you select a din through hole with a counterbore,
e.g. for screw din en iso 4762 M8, the depth is 9 mm, but the standard uses 8.6 mm
Good catch, Norman.
Inventor Counterbore depth sizes are ok with DIN 74 Part 2. I found a note (May 1991), that they shall be replaced with DIN 974 Part 1 . In that note DIN 74 Part 2 is intended to be obsolete with April 1996.
Walter Holzwarth
Hi Walter and Norman,
This is a bug. We do have standard compliance issues (CC, hole table, and drawing). I have forwarded this thread to the project team and see if this is a known issue.
Many thanks!
