Corrupted model state instance
chad.schmidt
chad.schmidt
Anyone getting corrupted model state instance?  The image attached is an example of the error.  No, I'm not able to share the files.  It shows up in my model tree as an empty assembly.  Any workarounds?
chad.schmidt
I had to close the assembly that had the instance in it.  When it closed I opened the file that contained the model states and did a "rebuild all".  When I re-opened the file containing the instance it was back to normal.  Please Autodesk figure this out.  I really don't wanna have to keep going through this workaround.  I've seen this a few times now and it needs to get fixed.
CGBenner
@chad.schmidt
Hi Chad.  I get that you can't share your files, but if this is reproduceable on even a "dummy" file that you are able to share, would you be able to provide something like that?  I'm not a developer, but I know from past experience that seeing what you are experiencing makes diagnosing an issue much easier.
Chris Benner
johnsonshiue
Hi Chad,
The behavior is absolutely a Model State bug. However, we need the files to reproduce the behavior. Please share the files with me directly johnson.shiue@autodesk.com. I will follow up with the project team and see what we can do.
Many thanks!
Software Test Engineer
