EXPLODED VIEW LINE TYPE - Convert to double dash by default
0x3FA5
0x3FA5
Good morning.
The exploded view on the drawing shows solid trail lines, while they are supposed to be double-dash.
How to make inventor to obey the standard of the exploded view lines?
Couldn't find a way to do so, except of course selecting 100+ lines individually and modifying the type:
Should be:
theo.bot
This is defined by your style settings. So in your template, Check you object defaults and see what layer is used. Change the existing layer or create a new one (don't forget to set it as default in the object default). Save your changes to the style library and save your template.
0x3FA5
Oh wow, why would anyone do something like that??
Thank you!
