Inventor Forum
Copy Object produce grey icone, invisible, unusable Composite
7 REPLIES 7
Message 1 of 8
772 Views, 7 Replies
Hi all, in an assembly i'm working on ive a starting part was using to derive some surfaces with Copy Object tool, to  produce other parts in other sub-assembly.
Now, when I do it, I'm able to select the surface from the staring shape, but the resulting composite surface derived in the sub-assembly have a grey icon and is invisible, and i can't use the Thicken/Offset feature to derive  bodies from it.
Can anyone help me?
7 REPLIES 7
Message 2 of 8
And, if i open the sub-assembly separatly, i'm able to see the generated surface and work with it...
Message 3 of 8
salariua
I was about to say that it turned invisible.... Is this a new part where you copy the surface? have you changed design view on it?
If you can replicate this on a new part then we might have a bug but we need to be able to replicate this on our end. Do a screencast and share the files if feel it's a bug.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 4 of 8
in reply to: salariua
Well yes looks like it is invisible but it is generated like this, and i tried to turn visibility on and of and keep being the same.
So do you think may be a bug?
Message 5 of 8
salariua
can you do a screencast (download link here)
and share the files if possible if not let us know and we can have just guys @ Autodesk to look at them.
Adrian S.
blog.ads-sol.com
Message 6 of 8
johnsonshiue
Hi! I think probably you have the following option unchecked.
In the top assembly, go to View -> Object Visibility -> Construction Surface. Is it unchecked? Please check it so surfaces will be visible when you are editing in place.
Many thanks!
Software Test Engineer
Message 7 of 8
in reply to: johnsonshiue
Bingo!
Message 8 of 8
That worked!
