Inventor Forum
Copy and rotate solid
8 REPLIES 8
Message 1 of 9
tmccar
2436 Views, 8 Replies
What is the best way to copy (and rotate ) a solid body in Inventor LT?
8 REPLIES 8
Message 2 of 9
Curtis_Waguespack
in reply to: tmccar
Hi tmccar,
You can use the Rectangular Pattern, Circular Pattern and Mirror tools to create copies of solids.
All of these tools have an option to pattern (or mirror) the entire solid  and a create New Bodies button   that will create the "copies" as new separate solid bodies.
Circular Pattern
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-B9D71D5C-C3D8-4089-A326-9DCC2B5331B1
Rectangular Pattern
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-C1A1FF2B-082E-4D50-911E-10343611F276
Mirror
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-8A7CFDA4-D362-4A52-BE34-40FCEA538D74
Here is a video of new solids being created using the Circular Pattern tool, in this case being used to create a cut feature using the Combine tool:
http://youtu.be/11dyV4InbmI?t=3m
Once the new body(s) is created you can use the Move Bodies tool to rotate the new solid, if it needs additional positioning.
http://inventortrenches.blogspot.com/2011/06/change-origin-of-imported-model.html
I hope this helps.
Curtis
Message 3 of 9
tmccar
in reply to: Curtis_Waguespack
I thought this was what I needed but...
I want to be able to rotate a solid (or feature) by itself. If I use circular or rectangular pattern, I have to keep the original part. But I want to delete the original part.
Message 4 of 9
JDMather
in reply to: tmccar
@tmccar wrote:
.. If I use circular or rectangular pattern, I have to keep the original part.
In your original problem statement you indicated Copy...
...since you don't need to Copy, simply use the Move Body command as decribed above.
Message 5 of 9
tmccar
in reply to: JDMather
But I don't get the option to rotate in "move bodies":
Message 6 of 9
in reply to: tmccar
Which program year are you using? Because if 2015, you should be able to move the body into an assembley and from there use the free move and free rotate commands. These will enable you to move the body and rotate it to wherever you may need. However as far as I know, there is no way to correctly measure this. Not sure if this helped or not but that's my input and best of luck to you!
Message 7 of 9
On second thought after trying this, I would not advise using those commands if the body has a large number of intricate parts on it.
Message 8 of 9
Curtis_Waguespack
in reply to: tmccar
Hi tmccar,
Click the icon as shown to activate the "Move Type" action line in the dialog and then you should see a drop down option to change the action from Free Drag to Rotate as shown in the earlier image.
Related Links:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-716726B8-1CE9-4646-849D-F7ADD1923419
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-2A8214B1-9A88-426F-8E88-B10F78917821
I hope this helps.
Curtis
Message 9 of 9
tmccar
Doh! Yes, that will do it, thanks
Technology Administrators
