Converting VBA script into Python (+comtypes) script
Dear community,
I want to convert this script:
Public Sub GetExtrudeFeature()
   Dim partDoc As PartDocument
   Set partDoc = ThisApplication.ActiveDocument
   Dim oSTLTranslator As TranslatorAddIn
   Set oSTLTranslator = ThisApplication.ApplicationAddIns _
        .ItemById("{533E9A98-FC3B-11D4-8E7E-0010B541CD80}")
  Dim oContext As TranslationContext
  Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
  Dim oOptions As NameValueMap
  Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'    Save Copy As Options:
'       Name Value Map:
'               ExportUnits = 4
'               Resolution = 1
'               AllowMoveMeshNode = False
'               SurfaceDeviation = 60
'               NormalDeviation = 14
'               MaxEdgeLength = 100
'               AspectRatio = 40
'               ExportFileStructure = 0
'               OutputFileType = 0
'               ExportColor = True
  If oSTLTranslator.HasSaveCopyAsOptions(partDoc, oContext, oOptions) Then
    ' Set accuracy.
    '   2 = High,  1 = Medium,  0 = Low
    oOptions.Value("Resolution") = 1
    ' Set output file type:
    '   0 - binary,  1 - ASCII
    oOptions.Value("OutputFileType") = 1
    oContext.Type = kFileBrowseIOMechanism
    Dim oData As DataMedium
    Set oData = ThisApplication.TransientObjects.CreateDataMedium
    oData.FileName = "C:\Users\t.pietrowskie\Desktop\Plate.stl"
    Call oSTLTranslator.SaveCopyAs(partDoc, oContext, oOptions, oData)
  End If
  MsgBox oData.FileName
End Sub
into a Python script. So I found comtypes and began to write this code:
import comtypes.client
ThisApplication = comtypes.client.GetActiveObject("Inventor.Application")
But at the last line, it fails because the object has no ActiveDokument, but I have one open and the macro inside Inventor works.
(What comtypes does is connecting to the COM service of Inventor.)
Do you have an idea or at least an hint how to get this working?
Thanks!
Replies (8)
Could it be that the missing API functions are due to the trial I'm using?
MechMachineMan
Are you sure that the ThisApplication call is actually returning an object of the valid type for the call to be made on?
Should you use an error loop/test such as "If ThisApplication = Nothing" to check that it's properly returned?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Well, what I'm getting back as a type is:
<class 'comtypes.POINTER(IUnknown)'>
What works correctly is:
Whenever I have Inventor closed, the script fails and complains it couldn't connect.
MechMachineMan
Sounds about right.
Try adding in the test as suggested and let us know if it does in fact return not empty so we can be 100% sure that the issue is beyond the function call.
Also, is the win32client an old/inappropriate method? because I see a lot of samples and discussions regarding such a way in my searching.
Justin K
I already tried that, but it was not working.
Something I haven't tried is: win32client
Is is simply an alternative to comtypes. Both are 3rd-party modules.
Thank you for the hint, so I can investigate into this!
Hey Justin,
taking a look on win32com was worth it! We are not really close, but we have to find a way how to set options in a iProperty.
What Python does not understand is this:
Using brackets Python expects a function to be called and you can't assign a value to a function that needs to be called. So I thought it might behave like a dictionary in Python:
Options.Value["OutputFileType"] = 1
.. , but this does not work.
I noticed that I can also get the value not only by:
but also by:
Options.Item("OutputFileType")
So are there more members I can use on "Options"? A function, which allows to set values by keyword? Eg. "Options.Set("OutputFileType", "STL")"?
Here is the code I've got over here.
# -*- coding: utf-8 -*-
Created on 07.11.2017
@author: Thomas Pietrowski
@api: http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-AA811AF0-2494-4574-8C43-4C22E608252F
import os
import ctypes
import win32com
win32com.__gen_path__ = os.path.join(os.path.split(__file__)[0], "gen_dir")
import win32com.client
import pythoncom
#ThisApplication = win32com.client.gencache.EnsureDispatch("Inventor.Application")
try:
    ThisApplication = win32com.client.GetActiveObject("Inventor.Application")
except:
    ThisApplication = win32com.client.Dispatch("Inventor.Application")
    #ThisApplication.Visible=True
foreign_filename = "C:\\Users\\t.pietrowskie\\AppData\\Roaming\\cura\\3.0\\plugins\\CuraInventorPlugin\\CuraInventorPlugin\\test\\Inventor Professional 2018\\test_cube.ipt"
#Document = ThisApplication.ActiveDocument
# Open files
open_documents = []
if ThisApplication.Documents.Count:
    for i in range(ThisApplication.Documents.Count):
        open_document = ThisApplication.Documents.Item(i+1)
        print(open_document.FullFileName)
        open_documents.append(open_document)
if foreign_filename not in open_documents:
    document = ThisApplication.Documents.Open(foreign_filename)
    document_opened = True
else:
    document_opened = False
STLTranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{533E9A98-FC3B-11D4-8E7E-0010B541CD80}")
Context = ThisApplication.TransientObjects.CreateTranslationContext()
Options = ThisApplication.TransientObjects.CreateNameValueMap()
#    Save Copy As Options:
#       Name Value Map:
#               ExportUnits = 4
#               Resolution = 1
#               AllowMoveMeshNode = False
#               SurfaceDeviation = 60
#               NormalDeviation = 14
#               MaxEdgeLength = 100
#               AspectRatio = 40
#               ExportFileStructure = 0
#               OutputFileType = 0
#               ExportColor = True
if STLTranslatorAddIn.HasSaveCopyAsOptions(document, Context, Options):
    # Set accuracy.
    #   2 = High,  1 = Medium,  0 = Low
    # was 4
    res = Options.Value("Resolution")
    res = 2
    print(Options.Set)
    print(dir(Options.Value("Resolution")))
    print(Options.Value("Resolution"))
    # Set output file type:
    #   0 - binary,  1 - ASCII
    Options.Type = ThisApplication.IOMechanismEnum.kFileBrowseIOMechanism
    filedir, filename = os.path.split(foreign_filename)
    # if "." in filename
    real_filename = os.path.splitext(filename)[0]
    stl_filename = real_filename + ".stl"
    stl_fullpath = os.path.join(filedir, stl_filename)
    Data.FileName = stl_fullpath
    print("saved as: {}".format(stl_fullpath))
    STLTranslatorAddIn.SaveCopyAs(document, Context, Options, Data)
if document_opened:
    document.Close(True)
PS: Here on Python I can't see any members. It is like coding in the dark..
MechMachineMan
Glad it's mostly working for you.
As far as the options, thing, here is all I can find:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-5FDFF606-1D15-4FA0-9ED1-1BF4A3BCEBF8
Justin K
Continued hacking around and now it works. Before using Insert, I had to remove the entry from the map, but now it works!
You can input .ipt or .iam files and get .stl files.
import os
import ctypes
import win32com
import pythoncom
try:
except:
#foreign_filename = ".\\test_cube.ipt"
foreign_filename = ".\\test_cube.iam"
# Open files
open_documents = []
else:
#       Name Value Map:
#               ExportUnits = 4
#               Resolution = 1
#               AspectRatio = 40
    # Set accuracy.
    # was 4
    # http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-5FDFF606-1D15-4FA0-9ED1-1BF4A3BCEBF8
    Options.Remove("Resolution")
    Options.Insert("Resolution", 2)
    Options.Remove("OutputFileType")
    Options.Insert("OutputFileType", 1)
    # IOMechanismEnum Enumerator - http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-A3660CD6-8B11-48CE-9FA5-E51DCC6F8DEB
    Context.Type = 13059 #kFileBrowseIOMechanism
    Data = ThisApplication.TransientObjects.CreateDataMedium()
if document_opened:
Also I found a typo in the VBA example code. However, now it works!
Thank you very much for leading me to the solution!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
