Converting Surfaces to Solid
- Mute
- Permalink
- Report
Greetings !
Can someone help me with the following issue.
I imported a step file (Reciprocating compressor Carlyle 06EA599) in Inventor.
It was imported as a composite surface. I try to Stich it but it failed.
Then I tried Repair Bodies and find gaps and leaks, the result obtained is attached.
It is showing me to edit about 1000 edges. which is getting very complicated.
Is there any alternative to how I can convert this surface to solid?
or do I have to select each and every edge and edit separately?
Also attached is the .ipt file
Really appreciate if someone could help me with this.
Thanks !!
