Hey,
I am using Inventor 2018.
Does anyone know how to convert a mate constraint to a flush constraint?
In my code I want to create a mate constraint between the XY Plane of "Rib Frame 1-1" and the XY plane of "FSP Body Fabrication" The code works but I want the XZ planes I want to constrain flush. Is there a way to convert the mate to flush or a way to constrain directly to flush without converting it?
below is my code:
Dim compOcc1 As ComponentOccurrence = Component.InventorComponent("Rib Frame 1-1:1") Dim compOcc2 As ComponentOccurrence = Component.InventorComponent("FSP Body Fabrication 1:1") Dim oWorkPlane1 As WorkPlane oWorkPlane1 = compOcc1.Definition.WorkPlanes("XY Plane") Dim oWorkPlane2 As WorkPlane oWorkPlane2 = compOcc2.Definition.WorkPlanes("XY Plane") Dim oproxyWorkPlane1 As WorkPlaneProxy = Nothing compOcc1.CreateGeometryProxy(oWorkPlane1, oproxyWorkPlane1) Dim oproxyWorkPlane2 As WorkPlaneProxy = Nothing compOcc2.CreateGeometryProxy(oWorkPlane2, oproxyWorkPlane2) Dim oAConstraint As MateConstraint oAConstraint = oAsmCompDef.Constraints.AddMateConstraint(oProxyWorkPlane1,oProxyWorkPlane2, 0) Dim oWorkPlane3 As WorkPlane oWorkPlane3 = compOcc1.Definition.WorkPlanes("XZ Plane") Dim oWorkPlane4 As WorkPlane oWorkPlane4 = compOcc2.Definition.WorkPlanes("XZ Plane") Dim oproxyWorkPlane3 As WorkPlaneProxy = Nothing compOcc1.CreateGeometryProxy(oWorkPlane3, oproxyWorkPlane3) Dim oproxyWorkPlane4 As WorkPlaneProxy = Nothing compOcc2.CreateGeometryProxy(oWorkPlane4, oproxyWorkPlane4) Dim oAConstraint2 As MateConstraint oAConstraint = oAsmCompDef.Constraints.AddMateConstraint(oProxyWorkPlane3,oProxyWorkPlane4, 0)
Solved by mcgyvr. Go to Solution.
Just change the first instances of
MateConstraint
to
FlushConstraint
When I try this:
Dim oAConstraint2 As FlushConstraint oAConstraint = oAsmCompDef.Constraints.AddFlushConstraint(oProxyWorkPlane3,oProxyWorkPlane4, 0)
I get this error
Error in rule: Place Ribs, in document: FSP Module 1.iam
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.MateConstraint'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{CEFDC141-B989-4BF3-BDD7-8308D8089FFE}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
and when I try this:
Dim oAConstraint2 As FlushConstraint oAConstraint = oAsmCompDef.Constraints.AddMateConstraint(oProxyWorkPlane3,oProxyWorkPlane4, 0)
It will create a mate constraint.
