Converting Inventor Surface Models to Solid
Mohammad.choudhary
Message 1 of 26
Mohammad.choudhary
I appreciate this topic has been discussed numerous times however I have spent hours researching watching videos of how to repair a surface model into a solid model. Is there a simple method of converting surface to solid? Can you convert to solid from importing window?  I am importing a SAT file into inventor and converting to an .IPT.  I have attached a typical file I need converting to a solid. Any help would be appreciated.
Replies (25)
Message 21 of 26
JonathanKruger
Set the properties of the surface and change the colour. EDIT: Thanks for the correction @JDMather . Here is a little Video for more clarity on how to set the appearances https://autode.sk/3R5FnRZ
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
Message 22 of 26
JDMather
@JonathanKruger wrote:
 Just note that the surface wont go through to the drawing environment.
@JonathanKruger
This is incorrect information.
Surfaces can be used for 2D documentation just like solids - you just have to tell Inventor to use them.
Message 23 of 26
JonathanKruger
Oh, My bad I always remember it being a issue to get Inventor to show the surface of a part file that had mixed objects in it, I have corrected my post. @JDMather Could you post the steps as I did look briefly but didn't see any options to show the surface so I must be missing a step somewhere. Glad to learn something new
Message 24 of 26
JDMather
@JonathanKruger
Include ipt surfaces in drawing...
Message 25 of 26
JonathanKruger
Thank you, I was definitely looking in the wrong place. I see why you are the CAD Whisper
Message 26 of 26
cadman777
I agree Sam, but only if it's a 'one-off', and like you said, not needing any modification.
Here's more reasons why:
1. If I need to scale it or modify it, then on IV2010 it needs to be a solid, b/c in IV2010 a Derived surface disappears in the Child part. Does that happen on 2023?
2. Editing a surface is more time consuming and difficult than editing a solid. So the question in my mind is, will the initial conversion from surface to solid be more time consuming than subsequent edits to the surface assembly? I found that most of the time it's easier to just fix it or make a native Inventor model. The OP's model would be very easy to remake. Just Project some profiles and Spin and Extrude them. See attached, which took 15 mins to make ('a'=WIP, 'b'=final).
3. In IV2010, a section view will not show up correctly in a drawing, even with 'Include All Surfaces' ticked.
4. When a vendor file is complicated, and when it comes in as a complex surface or group of surfaces, you are then forced to delete a lot of garbage off of it. If not, it becomes a 'tumor' in your assembly. Motors and gear reducers are good examples (esp. motors with all those useless fins!). On a large assembly, it adds to computing resource drain.
So, before vendor provided 3d models became readily available to us, I found it easier to just throw together a native Inventor model, or fix the surface mess by making it into a solid. Motors are very easy, b/c they have 2 cylinders and a rectangular extrusion, and sometimes (on huge motors) a 'doghouse' on top. Once you have one made, you can reuse it in new projects by making a few dimensional changes to change the sizes of its features.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
