- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
I am having a problem exporting a parametric model from Inventor assembly file to AutoCAD. If you look at the two jpg files below you can see what happens when I convert the files from an IAM to a DWG file. Some items to notice are the first 3 columns are extended in AutoCAD the ladders on the smoke stack are shortened, the upper platform has be blown apart and modified, our duct work has be resized and rearranged etc. This inventor IAM is a sales reference sketch for the customer. It is fine sent as an IDW file/ PDF. The 3d dwg file is for in house final engineering to use. This AutoCAD model is unusable at this time. It is a part of our process and down stream engineering to use autoCAD as our base documentation software. If we continue this way our sales pre-engineering information would be scratched and the processes would have to start from a blank slate. What is the best way to go from an IAM file to a 3D DWG file? I have the few options I know. file export.... saveas... etc. all come out the same. Some more techy folks said try it on a different machine. I am not sure why but I did and predictably the same thing happened.
