Need help converting idw/dwg files to pdf to 1 :1 scale retaining it's previous paper size. Is there a way to convert these files on a mass level?
Solved by BrienC212. Go to Solution.
Solved by vbracyH7K6G. Go to Solution.
Solved by A.Acheson. Go to Solution.
This can be done with VBA or ilogic. So it would be best to have this post moved over. We can call in the moderator to have it moved if your wanting to carry this out by code. Have you looked at this forum? the https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/bd-p/120
You will likely find a similar or partially similar code to modify. A simple internet search using keyword ilogic drawing view scale and pdf print will bring up some web pages.
