Inventor Forum
Converting dwg/idw to pdf. "Mass Conversion"
4 REPLIES 4
vbracyH7K6G
428 Views, 4 Replies
Need help converting idw/dwg files to pdf to 1 :1 scale retaining it's previous paper size. Is there a way to convert these files on a mass level?
4 REPLIES 4
A.Acheson
in reply to: vbracyH7K6G
This can be done with VBA or ilogic. So it would be best to have this post moved over. We can call in the moderator to have it moved if your wanting to carry this out by code. Have you looked at this forum?  the https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/bd-p/120
You will likely find a similar or partially similar code to modify. A simple internet search using keyword ilogic drawing view scale and pdf print will bring up some web pages.
Regards
Alan
vbracyH7K6G
BrienC212
Hello, There is an app on the app store called Fyenite which should be able to accomplish this. I believe it can also export the part/assembly file to stl , stp or igs. Link here : Fyenite
gsimeon724
in reply to: BrienC212
This is a pretty cool app.
Technology Administrators
